Golf 7 Tdi 2.0 Bremsen tauschen
    • Golf 7 Tdi 2.0 Bremsen tauschen
      Hallo.
      Ich muß bei meinem Golf 7 die Scheiben und Beläge hinten wechseln. Meine Frage da ich eine elekt. Feststellbremse habe: Kann ich den Bremskolben mit dem Spezialwerkzeug zurückdrehen oder braucht man eine Werkstatt die es über die Software einstellt ?
    • done7 schrieb:
      Anleitung hintere Bremse wechseln (mit VCDS)
      @koenigdom Schau dir das folgende YT Video, da erfährst du alles:
      Textauszug für VCDS:
      "Basic Setting
      Caution!
      • Do not perform any of these Basic Settings while the brakes are disassembled! Opening, closing, function tests, and otherwise cycling the Electronic Parking brakes should only be done with the pads and calipers properly installed on the rotors.
      • Please follow the procedures EXACTLY. There's a reason for every step. If you skip any prerequisites or other steps here, you are likely to experience "issues" for which no documented resolutions exist, in which case we will not be able to help you resolve them.
      • It is strongly recommended to run a full Auto-Scan first thing to check for any preexisting faults! There have been several reports of repair shops damaging the Electronic Parking Brake System when trying to do rear brakes, but not telling the customer and then sending the car out the door.
      Open Rear Parking Brake
      Prerequisites:
      • Connect a battery charger as per repair manual.
      • Cycle the Parking Brake ON, then OFF first.
      [Select]
      [03 - ABS Brakes]
      [Basic Settings - 04]
      Select Start lining change mode
      [Go!] to activate the Basic Setting.
      The brake calipers will then open, allowing the pads to be changed.
      You should hear the rear caliper motors operating.
      Wait 30 seconds after it says Not Running or the noises have stopped before clicking [Stop]
      [Done, Go Back]
      [Close Controller, Go Back - 06]
      • Turn ignition off and leave battery charger connected.
      The caliper pistons do not move back into the caliper, they must be pushed in using a hand tool. Fault code 721152 - Brake pad replacement mode active will be stored, this is normal.
      Close Rear Parking Brake
      Prerequisites:
      [Select]
      [03 - ABS Brakes]
      Select End lining change mode
      The brake calipers will then close.
      [Done, Go Back]
      • Turn ignition off
      The LED in the parking brake switch and the warning lamp in the instrument cluster will probably continue to blink rapidly in addition to Fault code 721152 - Brake pad replacement mode active. This should stop after cycling the Parking Brake ON, then OFF again using the switch in the vehicle while holding the brake pedal AFTER all rear brake components are reassembled."
      Quelle: VW Golf VII (5G/AU) ABS Brakes - Ross-Tech Wiki
